9-20-2015 |
3.00 |
Cut out winglet bottom for rudder and add micro |
It was time to cut the winglet bottom for the rudders to fit in. Lots of cut and try then sand to get close. I see that the transition will need work and foam will have to be glued on and then shaped. The good side is that I got time in on the plane. Wedding, Fall Fair, Snow Plow, all got attention this weekend as well. |
