Date:    7-21-2015
Number of Hours:    3.00
Brief Description:    Sand all the wells and hand paint on primer. Bid w
I spent the night getting the wells ready for primer with a good sanding and fitting. The winglets just needed a small amount of sanding to have a good match.
Yes I jumped the gun and had to sand off the wing ends at the rudder area so the cut faces butted up straight and level. All is good. I applied the one bid now to finish the end of the wing.
