5-3-2015 |
4.00 |
Spot-Lite bondo is the tool to use for me |
Added Spot-Lite to the top of the wings and sanded off filling in the scratches and finding more low areas to fill in. I mixed up the Spot-Lite and spread out on the wing then I scraped it off only filling the scratches the applied again until it set up and I could not use it any more. I mixed up about 20 small amounts per wing to get it done. It was cheaper doing it this way then to spray out $75 in primer to just sand off. I used about $15 in bondo to fill the scratches. I will now used Spot –Lite to fill and blend any low areas to have a smooth transition and shape for a great finish. |
