Date:    4-7-2015
Number of Hours:    3.00
Brief Description:    Found a few bigger areas needing work
I blocked out the bottom Pilot strake and then worked on the top and found a few areas needing work. The Pilot door was one spot and then a bigger area on the top strake. The pinholes are getting filled and not many of them left to do. A few shots of primer on these areas and then block out again. I still have the bottom to do and will need to use my creeper for this to roll around on.
