Date:    1-27-2015
Number of Hours:    4.00
Brief Description:    Sanding filling and more sanding
I finished glazing up the wings for pinholes and let set for 5 hours and did other things besides work on the plane. I then sanded the micro added to the strakes and used the 3’ sanding board to level out. I then got my sanding gear to sand the radius on the strake to fuselage. This is very slow work trying not to screw up removing to much and changing what I’m looking for in the right shape. I have a few spots to fix and maybe the fuselage will see primer on the weekend.
