1-20-2015 |
2.00 |
Working on fuselage stakes and fuselage radius |
Icing was applied after the strakes were sanded for high spots. I’m getting very close to were it needs to be before primer is sprayed on. I also radius the fuselage to strake tonight with a tong depressor the micro was starting to set up in 25-30 minutes. This is OK for me it should be ready for sanding in the morning. |
