Date:    10-19-2014
Number of Hours:    0.00
Brief Description:    Wing and strake front end
My new laser showed up from Amazon and it was time to make a better cut for the wing. I lined up with the top and bottom and it worked out better then the eye ball method.
I won’t to get as much done on the fuselage before I kick it out side under the truck shelter. I will be working on the wings and canard this winter with filling and sanding to primer.
I then sanded and cleaned up the front storage area on the strakes for my tie down straps, they should fit very well in this space
