Date:    10-16-2014
Number of Hours:    3.00
Brief Description:    Finish up strakes at door and baggage
The time was right, we had finished working on the rental house for the night and Cynthia was off to Can-Can dancing so it was Velocity time. I finished sanding to 3/16th clearance at the door to strake and started to mix resin when the entire wipe down was done. I picked up a small mirror to see behind the storage area for the micro job and it did help before the glass 2 bid was laid in place. I wetted out some of the glass in place on the thin areas and then applied peel-ply on the work area.
