7-29-2014 |
2.00 |
Had to clean Sticky stuff Dispenser |
My Sticky Stuff Dispenser was not giving perfect shots of hardener, so let’s see what is in the bottom of the tank. I pump the tanks out back into there containers to find the bottom of the hardener tank full of crap. I drained the rest of the 2 tanks out into the garbage and clean the tanks out with paper towel and then Acetone. The picture only shows 1/5th of what was in the bottom of the hardener tank. I then washed down with Acetone and pumped clean Acetone trough the system. It is now ready for clean resin again. I heated the resin in a bucket of boiling water from the kettle to dissolve any solids. I had some nylon window screen and cut out 2 pieces to use for screening out crap for both tanks. The pump was primed back into the containers and is ready to go back to dispensing again. |
