Date:    6-12-2014
Number of Hours:    2.00
Brief Description:    Install toe brake cylinders
The longer bolts I needed come in so the job was to install the toe brake cylinders. I used washers to space the cylinders away from the peddles to eliminate any rubbing. I need to plum the cylinders in now.
