5-14-2014 |
3.00 |
Assemble rudder pedals with push pull bell crank |
I got to work installing the toe brakes pedals and push pull bell crank. The bolts will have to be tightened up later on as it will have to come out again to seal up the holes in the bulk head with rubber dampeners. The manual said drill 1” holes for the rods and low and behold the holes were 1” after all, fitting in and out about 8 times. |
