Date:    2-24-2014
Number of Hours:    2.50
Brief Description:    Glass in gear leg well
Tonight after work I had to do some more trimming before glassing in the gear leg well.
As I pulled the wheel up (I have a wire through the carter pin hole in the axel) it moves to the fuselage and came in contact with the cover I sanded to give me a 3/8 – ½ clearance. Now I can start the glassing in work. Sanded everything up--- put in place and used tong disperses to push open to the sides—bondo in place and mixed up micro and resin—sanded bondo smooth ---blew off and wiped down with acetone---painted a very light amount of resin on gassing area and applied the micro---got the bid cloth wet with resin and put in place---added peel-ply.
One more step done.
