2-21-2014 |
2.00 |
Prep for lower strake to fuselage lay-ups |
I got home from work and pulled the peel-ply off from yesterday. I had a look at the incidence and it was still dead on. I set up to cut the wing free with a trouble light shining from the top to show me center for the cut. The line was marked and the cut was made. Now the wing is free and the incidence can be changed before attached to the fuselage. I made a slight adjustment and got ready for the strake to be screwed to the fuselage from inside. I mixed up bondo and did a fillet bondo joint to hold in place and then removed the screws for cutting out the baggage area to size. I had rough cut the baggage area the day before and just had to remove a small amount it is sanded and ready for lay-ups. Time to cooks supper for Cynthia Shrimp stir-fry tonight HAPPY WIFE HAPPY LIFE!!!! |
