Date:    2-18-2014
Number of Hours:    2.50
Brief Description:    Cut and fit upper stake Pilot side
Bit by bit I cut and removed the side of the strake to get it close for the last cut and sanding. On both lower and upper I had to remove more at the back end to have it swing over to fit the wing. Once it was in the right spot I made a few cuts to fit the right width at the wing.
