Date:    2-16-2014
Number of Hours:    7.00
Brief Description:    Cut end of wing and cut in lower strake
Today was a big work day for me. I got the wing to the right location on the cradle and got one bolt in place. From there the other 2 holes had to be matched for the bolts to slide into place. From there I started to cut the lower Pilot strake and after a lot of 1/2” cuts it was close to have the wing end cut for final fit. I then got the strake ready for the glass work needed by cutting and removing foam at the back part of the strake.
I sanded the fuselage side ready for glass work here as well.
