Date:    2-5-2014
Number of Hours:    2.50
Brief Description:    Fuel cap installation
Well I found some cutters and made a hole for the cap. I installed the ground wire with a rivet and drilled the outer rim for the structural T88 with fiber to squeeze trough the holes and then filled with micro. I then added 2 bid lay-ups overlapping to cover all areas well. I got out the peel-ply and finish off. It was a race out the door to Fire pratice.
