Date:    11-30-2013
Number of Hours:    2.00
Brief Description:    Lower strake alignment
I leveled the main spar and followed the instructions as to the manual with a level line from the bottom of the main spar up to the doors. I used a water level to see if both side worked out. The out come was good and will leave it as is for the strake front spot on the door.
