5-30-2013 |
3.00 |
Removed fuselage over light swiches |
The switches are deeper then the fresh air channel so some of the fuselage roof had to be removed for space. I cut the glass and sanded out the foam. A few days later I micro filled and did a 2 bid lay-up to fill in the cut out stuff. Peel-plied up and let set. |
