Date:    5-18-2013
Number of Hours:    2.00
Brief Description:    Dowels for kick plate aluminum strip.
After the micro balloons set holding the foam I sanded to shape and got ready to inset the dowels for the aluminum strip that will sit on top the foam to complete the kick plate for the door. I also used spray foam to fill in the bottom open space to get ready for the lay-ups. After the spray expanding foam set up (2hrs) I cut to shape.
