Date:    5-12-2013
Number of Hours:    1.75
Brief Description:    Foam for door kick plate
I will be using foam to make the door kick plates. I micro glassed the foam into place after shaping. I will need to file and sand to shape install wood dowelling for the aluminum strip on top to screw too and than do a 2 bid lay-up to finish this off.
