Date:    5-15-2011
Number of Hours:    2.00
Brief Description:    Preparing for Landing Lights
With the drilled Landing Light Lens in place I used a Sharpie to mark where the matching holes should be in the Landing Light Lens Mounting Frame and then carefully drilled the matching holes. I was worried about using my standard drill bits in contact with the Plexiglass Lens so I decided that if I was careful I could drill these holes (which will be oversize to allow for the dissimilar rates of thermal expansion between Plexiglass and Aluminum) accurately enough. Image 1 shows me drilling those holes. I was almost right. I managed to drill all but one hole in the Mounting Frame what looked to be dead center to the Sharpie mark but one wandered. So I made a tool from some of the 1/4" Aluminum strip I bought and using my drill press made a tool that I could cleco in place and then drill the final oversize hole where I needed it. The tool is shown ready to be used in Image 2 and it worked as desired to put the hole where it belonged. Image 3 shows me using a Platenut Drill Jig again to drill the holes for the Floating Platenuts that will fasten the Landing Light Lens in place.
