Wanted to show that I managed to get the Inboard and Outboard brackets installed sufficiently square that they are not quite 1/8 degree off from level (or very nearly parallel with the main spar) and that tells me I ought to be able to adjust them so they converge at a spot in front of the airplane. Image 1 is looking from below the wing and up, and Image 2 is almost straight ahead of the airplane. Image three is to show that I've cleco'd on two more strips of 0.025 Al sheet to help hold the parts square.
