Date:    9-11-2010
Number of Hours:    1.00
Brief Description:    Preparing for Landing Lights
Cut out two more Plexiglas blanks as close to the same dimensions to each other as possible so I might have a chance for "intechangeable parts". After cutting the two blanks out I taped them together and sanded the different edges using my disk sander and a find grade of sand paper. I carefully sanded the four corner radii as a unit and finished sanded all edges by hand using 320 grit multipurpose dry sanding paper.
