Date:    4-10-2009
Number of Hours:    2.50
Brief Description:    Preparing the Elevators
Continued preparting the Elevator parts for priming. I again used Prekote which worked very well on the Horzontal and Vertical Stabilizers and the Rudder. The process is simple: 1) Spray Prekote onto the part, 2) Use a maroon Scotchbrite pad to scrub the surface of the part and generate a good lather 3) Spray more Prekote and scrub some more, 4) Rinse the parts in clean water (I use my garden hose), 5) Allow to air dry.
