Date:    7-28-2008
Number of Hours:    2.00
Brief Description:    Priming the Empenage
For the most part I chose to hang parts from above using safety wire with the idea that I could get access to all sides of the parts that way but in the end I wound up setting up a low shelf and setting many parts on it. I means I will have to spray those parts a second time.
I purchased the forced air system (Hobbyair with the full face mask) from Aircraft Spruce in Corona, CA, the one-piece Tyveck suit (purchased 5 suits) and rubber gloves (5 pair) from Gemplers, and the spay gun (DeVilbliss Starting Line) and DeCups kit from Eastwood.
The primer is from Sherwin Williams CM0484900 Corrosion Resistant Epoxy Primer.
