Date:    4-24-2014
Number of Hours:    5.00
Brief Description:    Trim sides, finish electrical channel.
Trim upper longeron layup. Refit right side to form with bondo at 7/8" spacing.
Mark where electrical channel should go to firewall, based on full size drawing of firewall, slightly different to measurement in plans, got this hint from FAQ.
Noticed epoxy box was at room temperature, explaining difficulty wetting out yesterday, replaced blown heater bulb.
Notched lower longeron as per plans, even though mine have a square section at the rear.
Cut triangular notches in I-clamps. Fitted lower longerons with flox at measured position. Located at W.L. by nails, clamped with the I-clamps, with the wedge underneath. Broke it between notches in a couple of places. Fixed with flox and extra nails.
