2-27-2014 |
1.00 |
F28 - rear face |
Applied 2 x BID @ 45 degrees, and one UNI laterally. Had to say it once. Will only again if I do something different to plans for some reason, or want to emphasize a detail. FHC stiffeners applied to wet layup and 3 x BID applied with 1" overlap onto F28. Found UNI to be very frizzy at edges, will follow plans reccomendation in future to tape edges then trim. [Time warp 22MAY2014, just discovered pizza cutter will trim off the tape, but not cut the peel ply underneath]. |
