8-3-2020 |
2.50 |
Strake lower skin prep |
Trimming the top seam of the luggage compartments continues, including flox corners everywhere the tape with cross a foam/glass boundary. Very little sign of the flox I smeared around here before, I think I've trimmed it all off. I noted the crap-ness of a couple of other tapes done under the upper longeron with the fuselage the right way up, and trim and mark them for repair also. Secure the fuel probe wires under the upper longeron with dabs of hot glue. Trimmed the outboard OD/bottom strake skin/spar/fuselage joins. For fun I tried blowing in the smoke oil delivery tube with my finger over the vent, and discovered an obvious leak. :( Marked for further attention. |
