Date:    7-26-2020
Number of Hours:    4.40
Brief Description:    OD bulkheads and fuel lines
Flox in the fuel feed lines from both blisters to the sump tank, and the feed from the sump tank. Clamp them with a rats nest of stick props, which fall down a lot. Secure line ends in place with multiple layers of 4oz cloth, all with EZpoxy. Tape the delivery line inside the sump tank with 2 x 4oz and extend the existing t-hats to the fuselage bottom with 2 x 4oz.
Secure the pipes between the ends with more 2 x 4oz tapes, with MGS epoxy. Taped the port line where it will go under the port rear seatback with 1 x BID, for a bit of extra resistance.
Taped between the starboard OD bulkhead, (smoke oil tank) and the spar/top strake skin with 1 x 4 oz, then 1 x BID over both OD bulkheads, lapping 1" onto centersection spar front face.
Leftover resin turned to dry micro and filled some strake top skin grooves.
