Date:    2-12-2020
Number of Hours:    4.80
Brief Description:    Strake bulkheads
Finished marking up bulkheads. Detach a few bits, and reassemble into a nicely coverable sheet with toothpicks inserted in the edges.
I had planned to do both sides, but time did not permit, so 1 x BID over both the back side of the bulkheads with peel ply, using AeroPoxy laid on fairly wet with a little roller. 904g of resin used. Takes me a while to recall the resin just doesn't wet out without heat. Once I start using heat I retire the stippling brush, which wasn't doing very well either.
Flipped one set over and hardshelled with leftover micro. Experience indicates Aeropoxy does not live well in the freezer like MGS.
