1-28-2020 |
2.40 |
Turtleback drip rail |
Sanded back unsightly bump inside forward turtleback, for taping and repair. Trimmed the rain channel in the aft turtleback, and started oogering out the foam in the leading edge between the inner and outer skins with dremel wire wheel and 1/16" die grinder bit. The Cozy plans have you stick micro in here, but the Aerocanard plans suggest spar tape and flox. I like this idea, especially as my long term plans for a steel rollover structure are on the back burner. Note bubble under port upper engine mount reinforcement around the edge of the firewall. Mark it for resin injection. Discover box tape over fuselage extends too far back under fixed turtleback, so ooger it all out, pending repair. |
