1-27-2020 |
3.50 |
Upper engine mount reinforcement |
Used new resin to place 5 x BID from upper engine mount along the outside of the turtleback/upper longeron. Wet out over peel ply and transferred, but may have been a bit much for this concept, as it was difficult to make it follow the bends. 1 x BID over foam filler in firewall. Completed cutting off forward turtleback and started trimming. The plans have you do this after the clear forward canopy and deck is done, but I want access to the inside, and figure I can glue it on again with aligning sticks for that step. |
