Date:    1-17-2020
Number of Hours:    3.30
Brief Description:    Turtleback install
Trimmy, trimmy, all OK. Cut out the aft windows just for fun, with multitool and die grinder with sanding cones.
Taped aft of firewall to centersection spar, (layup #2).
In a change of pace, following a tip on the Cozy Builders forum, put 1 x ply of 4oz light fibreglass cloth over the spar and fuselage side inside the intended fuel tanks, with a wet coat of Aeropoxy, plus the 2 x BID tape over the joint and flox fairing.
