10-9-2019 |
3.20 |
Sump Tank bulkheads |
Marked up foam for bulkheads, tapered the trailing edge of one to clear the center seat belt reinforcement and applied 1 x BID each side with AeroPoxy resin, and pee ply, laid on wet. Still challenging to use this stuff. The shed is warm, but heat is required. I discover the rubber squeegee works really well, like the instructions suggest, whereas it is hopeless with MGS, the glass just slithers everywhere... |
