3-30-2019 |
0.50 |
Rudder trial installation |
Found no tool in the toolbox that adequately deals with installing the return spring onto the hook on the rudder. Bent up a bit of stiff 2.5mm wire to a pleasing shape and cut a slot in the flattened tip. Wrapped the result in bit of tape and it works well. Trial install the rudders a few times using nothing but my special tool and needle nose pliers. Takes seconds!!! |
