Date:    3-26-2019
Number of Hours:    4.20
Brief Description:    Rudder installation
Made a flat plate 'bucking bar' for the rivet squeezer and managed to fit in some more solid rivets. The rest can wait for BSC-44.
Over two days floxed on remaining hinge pin retainers, clamped with greasy cleco.
Opened up Rudder cores a bit through the return spring hook holes, injected runny flox and fitted hooks.
Slathered runny micro into remaining return spring hole and fitted tube assembly.
