Date:    1-4-2019
Number of Hours:    1.00
Brief Description:    Lower Winglet installation
Taped up amended pocket foam and trimmed foam over bellhorn, a little too enthusiatically.
Finished trimming right lower Winglet and fitted with urethane bond, secured with hot glue blocks/sticks. Wedged bits of wing foam in all the gaps, not looking for pretty, as Mr. Hacksaw-Blade can make it pretty later. Note after installation I have not notched the skin for the Bellhorn tip. Tape a note to myself.
Stuck filler piece of wing foam onto left Wing bellhorn.
Have decided on the AVEO Powerburst Daylite nav/strobe/position lights and cut a couple of mounts out of thin carbon fibre test pieces my clever eldest Son had collected for me. Intend to fit these under the skin on the wingtip, with Al slugs attached
