12-15-2018 |
1.60 |
Upper Winglet installation prep |
Trimmed right Wing tip as I did the left. Cut "Block A" from scrap wing foam, figuring it would be easier before attaching the winglet. Using it a guide cut another for the left Wing. Discovered I can stop the tape falling off the nail when I measure "C" by putting a dob of hot glue on the end of the nail. Roughly positioned the right Winglet as I did the left on the angle and prop and noticed the angle looked a bit different fore-aft between the two. Jigged the wings level and checked the actual angle with my angle finder and they were different by a lot, (I forget the actual number). This concept isn't mentioned in the plans, and I don't see why not. Decide the left is the more asthetically pleasing and move the right to match. This is also easier. Reset the A B C & added more glue blocks. Made some more glue blocks. |
