11-12-2018 |
2.00 |
Winglet outer skin trimming |
All parts OK, started trimming for a short time on the 11th, continued on the 12th, concentrating first on the trailing edges. Rough cutting with the multitool, and then sanding them straight with a long board. Prepped trailing edge overlap, (on the outside), and trowelled in dry micro. This micro was left over from the layup on the 9th, and has sat pretty in the home freezer since then. Still a bit left, so back in the freezer! I found this tip on the Cozy Builders Forum whilst looking for something else. Thanks guys! |
