7-18-2018 |
1.50 |
Left Aileron hard points |
Jigged Left Aileron to table so trailing edge is offset from the edge exactly the width of the Right Aileron. Used dremel router to excavate foam for LA13 counterweight. Used dremel die grinder to excavate foam for placement of other parts. Prepped and fitted LA2/5/10/13. Whilst mixing epoxy the lid came off my NEW squeeze bottle! Maybe something in the new batch of epoxy is attacking something, because it was tight, and now I can just pull it off. Didn't want to mix a 250g batch of expoxy, so syphoned off 42g and added the required amount of hardener. This is just going to micro, if it was for glass I would just bin it, but fingers crossed. Was intending to inject the bubble in the BL31 rib, but that can wait for another day. |
