5-29-2018 |
1.90 |
Right Aileron hinges |
Bonded in right Aileron clickbonds with wet flox, hinges held down with well greased hardware nuts at FT tension. Faired in clickbond heads with flox, 1 x BID over the heads, overlapping heads by 1" Played some more with CS127 and other Aileron hardware. Mounted all, mostly with un-torqued aviation hardware to check fit. Will have to remove it all to fit the Aileron torque tube, once I discover if the Aileron can actually be removed... |
