5-23-2018 |
1.00 |
Right Aileron hinges |
Removed Aileron, drilled reamed and hardware rivetted mid hinge to Aileron. Just in case, marked all non-aviation rivets with a black marker. Replace Aileron. It is aligned properly and moves beautifully! Played for a time with the leading edge Aileron gap on the lower surface, using 1/2" sanding drum and 6mm sanding board. In progress. |
