5-20-2018 |
1.20 |
Right Aileron hinges |
Trimmed layup and bondo'd inner and outer hinges to aileron by smearing from top surface. Not enought clearance to do center. Intend to mount inner and outer, and do mid from a stable position. Inner hinge fell off. Decided to mount the inner and see how it works. Drilled through the hardpoint. reamed to 1/8", removed the hinge, cleaned off the bondo, prepped, floxed and rivetted hinge half with BSPQ-43. |
