Date:    5-10-2018
Number of Hours:    5.20
Brief Description:    Right Aileron hardpoint installation
Trimmed A13 to match Right Aileron. Removed foam and trial fitted with hot glue/duct tape.
Re-fitted to wing and checked clearance. No problems other than a close gap with the Wing skin which I don't want to profile yet, plenty of clearance with the cove.
Tried a trial balance with all the hardware fitted. Sits with the top surface about 7 degrees tail down. My A13 weighs 2.65lb, I add the plans alloweed 0.3lb of lead on top, and this lifts the angle to about 5 degrees tail down. Figure it needs to be light anyway so do the final sanding on the skin, going into to the top layer of UND and getting it lovely and flat. Do another trial balance and NOTHING HAS CHANGED!
Drilled, reamed and deburred Aileron hinges for rivetting to the ailerons.
Started relieving foam for A2/A5/A10
