Date:    4-23-2018
Number of Hours:    0.90
Brief Description:    Right Wing Ribs
Continued prep for Wing Ribs.
Noted fantastic amount of resin blobs on bottom edge of RFC-1 spar, more evidence of Andrew's diligent squeegee work. Should have masked off the bottom of the Shear Web, under the overlap line.
Noted I have slightly overlapped the level board with the remaining UND reinforcement to go over the outboard hardpoint. Oops. Will hog it out rather than move it.
I am using an IGUS spherical bearing for the CS132R wing root mount, and play with how to install it. Decide on a 0.032" 2024-T6 plate, drilled to accept CS151 if required, with two nutplates for mounting the bearing.
