Date:    3-14-2018
Number of Hours:    6.20
Brief Description:    Right Wing top Spar Cap
Trimmed layup, all good.
Sanded/routed edges and removed dams.
Finish sanded foam. Note for the first time that the LE is not terribly straight. Bit of a hump in the middle, and a hollow beneath. Further investigation required.
Cut the trough for the Rudder cable conduit using Dremel router attachment against a bit of timber
Marked up plies for top skin, cut reinforcement bits and peel ply.
Can't do layup yet, waiting for a new batch of resin and nyloflow tube for the rudder conduit.
