3-9-2018 |
1.30 |
Right Wing top Spar Cap preparation |
Inspected repairs, all good. Inverted wing to reveal top surface and fixed jigs to table with hot glue blocks, all lined up nicely. Removed top jigs and cleaned them up. Removed 'fish tail' trailing edge with hand saw, started removing peel ply, (one inch at a time), and faired in the foam.[Timewarp 11JUL18: have finally discovered the peel ply comes off MUCH easier if you slice off as much foam as possible before trying to peel] Marked line for rudder cable conduit. Started RFC-1 spar cap dam. Made some more glue blocks out of old hardware store pallets |
