Date:    2-3-2018
Number of Hours:    3.00
Brief Description:    Left Wing Spar Cap preparation
Lined up Left Wing on table, bottom side up and removed lower jigs. Removed infestation of baby spiders from conduit. Ewwwww!
Marked up LFC4 at 90 degrees to root shear web and cut off with handsaw, finishing with sanding block.
Had a bit of practive with aft cores, removing remaining glue joins and lumps with dremel router and sanding surface with 240g. Cleaned up resin dribbles and lumps on aft side of shear web with dremel router. Sanded lumps around LWA4.
Experimented with holding TE straight with 3.5m straight edge and PVC angle. Decide I need two, so dissasemble extra bit off 3.5m and mate it to the off-cut from the extra bit, making a 3m and a 1m straight edge, joined together at the B.L.67.5 joggle.
Marked up the site for the aileron peel ply
