Date:    1-25-2018
Number of Hours:    2.40
Brief Description:    Left Wing hardpoints
Bent and trimmed W18, again using well sanded 0.032" 2024 T3 as I have no 0.016", and recessed its mounting point.
Made some more standoff jigs for installation.
Prepped Al, including priming exposed surfaces. and after cure installed with flox corners for LWA4/W18 and micro for LWA6. [In the wrong spot!!! As you can see in the picture it is on the side of the shear web on the bottom surface, is supposed to be on the top]
Filled some dings in the Shear Web foam with micro using left-over resin
