Date:    12-2-2017
Number of Hours:    0.90
Brief Description:    Right Wing Cores
Setup and made profile cuts RFC3/5. In the picture you can see I have set up both templates at the outboard end. The outboard template is fully aft, at the height wear the inboard template touches the top of the block. I don't see any arrangement where I will leave any more foam below for the winglet. After buggering up the lower cut RFC1 inverted the blocks for the bottom cut.
Cut spar cap trough RFC3/5
Setup for conduit and nose cut RFC3/5
Marked up for aileron block cut.
